Battery Drain! Intermittent
(Topic created: 01-16-2025 09:49 AM)
userlQcCM1wRc8
Black Hole
Discussions
Posted the following along with the system logs to the beta feedback.
Posting here to see anyone else is experiencing a similar issue.
Mine seems to be intermittent; however, even after rebooting and clearing partician cache, the battery has dropped from 85% to 82% in a matter of minutes.
About an hour ago, my battery dropped unexpectedly and very rapidly from 90% to 69%.
This happens every so often.
Reboot and Clear Partician Cache usually solves the issue for a while. I would like to understand why these sudden drops in battery are happening with normal usage of the phone?
Please see attached system logs.
Thank you!
eduauca
Cosmic Ray
Discussions
I also go through the same thing sometimes the battery runs out in an extraordinary way.
mikeo2776
Halo
Discussions
I am experiencing this also. I went from 100% to 30% in six hours. I was not using my phone during this period.
Discussions
My phone gets hot sometimes. Especially when YouTube is running. My charger doesn't always use fast charge as well
Ryanoutdoors
Nebula
Discussions
My battery life is amazing in my phone works great I did not have any battery drain issues get more than a day before I have to charge. Moderate to normal use
Discussions
Same.
Y0u
Honored Contributor
Discussions
Have you tried clearing the cache partition and run galaxy booster from good guardians and report this issue to samsung, so they can see what's eating the battery
userlQcCM1wRc8
Black Hole
Discussions
Yes to all of the above.
The issue is intermittent.
Be nice to figure out why this happens every so often.
Discussions
My battery life, I would say, is not that bad. I charge my phone up to 90 and after a 7 hour school day I end up with about 65+ percent. My usage is mostly music and social media.
Y0u
Honored Contributor
Discussions
Have you gone thru all your setting that could be eating the battery such as Bluetooth and location when not needed, some apps not officially optimized, but for some reason uninstall reinstall on some apps work, syncing etc
