Battery Drain
(Topic created: 10-07-2022 02:06 PM)
GALAXY777
Discussions
After installing, I noticed the battery drains much faster than before, even after days of monitoring.
Ryan891
Supernova
Discussions
Yep. I don't know if it will help you, but I ran Good Guardian App Booster. Although I'm sure we have very different apps installed and usage patterns, so I don't know if it will help or not
Coldheat06
Galaxy
Discussions
Thanks but I have already ran Good Guardian....... don't know what is wrong but Beta 2 had excellent battery life.......I was really happy with the battery then.
Ryan891
Supernova
Discussions
Maybe try to enter recovery mode, clear cache, then select repair apps. It really shouldn't be necessary, but it can help sometimes. I hope it gets sorted out for you
Coldheat06
Galaxy
Discussions
Thanks I have done that also last week, bit I will try it again
user_ams007
Planetary Samsung Care Ambassador
Discussions
Sorry to hear that the last update has affected your phone's battery life please check the settings in the device care application and put unnecessary applications into a deep sleep which will improve your phone's battery, also I like to recommend that you try Installing the Samsung Good Guardians application from the Galaxy store to optimize your phone's applications and also battery life and then see if things improve
USBetaModerator2
Beta Moderator
Discussions
Hello ,
Thank you for your feedback.
If you haven’t already, Please update Samsung Members app to latest version from the Galaxy store and send us an error report immediately after experiencing the issue from the Samsung member’s app -> Beta Feedback -> Error Reports to help us debug the issue.
We apologize for the inconvenience and appreciate your contribution to the beta program.
Regards,
One UI Beta Team
