Showing results forย
Search instead forย
Did you mean:ย
Battery ๐Ÿ”‹ Drain
(Topic created: 03-22-2025 07:49 PM)
Anant-
Discussions
I installed one UI 7 beta on Samsung s23+
There is a significant battery drain on the beta version. Hopefully final release will make it better. Any one else having this issue?
sameen
Discussions
I think I have the exact opposite experience. I think the battery management is much better with the Beta than what I had with Android 14.
ChaosSaber
Honored Contributor
Discussions
My S23 Ultra is fine
Mujibar
Honored Contributor
Discussions
I'm actually getting a little bit better battery life on the beta.
Comptrgeek
Discussions
When I first installed I noticed battery drain also. But oddly enough by the next day I was getting even better battery performance than I was prior. Not sure if a "settle in" period or what, but fine since.
BYates
Cosmic Ray
Discussions
I have S23Ultra, it seems to drain faster than normal, I'll watch it to see if it improves
ELIฤšZER
Cosmic Ray
Discussions
Let the update settle, it will take about 4 or 5 days, after that the battery should be better .
qwilson
Halo
Discussions
My battery was horrible bad bad horrible the first two days then I got way better but its for sure not as great as it was before downloading the beta. I'd say I loose about 15% more now then I did before. But it was more then 50% loss the first two days. I'm hoping it gets back to normal with the stable version.
Corbinblue29
Discussions
Yes agreed too much battery drain. I have the s23 ultra
MarcT
Discussions
I must agree have to charge my phone twice a day now. Battery drain is up!
