Battery Drain?
(Topic created: 04-16-2025 11:07 PM)
Maxxus72
Cosmic Ray
Discussions
Anyone notice increased battery drain, post Beta install on S23 Ultra ?
Dave249
Discussions
I'm actually going to say thr opposite. I think it's helped my battery
46m3csl
Comet
Discussions
Yes it's much worse, several post about it already
usert4AHFPdsAJ
Cosmic Ray
Discussions
Definitely increase ๐Ÿ˜ญ
DevinP
Discussions
Definitely an increase in battery usage. I'll take my phone off the charger, get ready for work, not even use my phone, and it will have dropped 15%-20% in only ~30 minutes of only being in my pocket without using it.
46m3csl
Comet
Discussions
Same here
USBetaModerator3
Beta Moderator
Discussions
Thank you for your feedback.
Yes, weโ€™ve received similar reports from a few S23 Ultra users noticing increased battery drain after the recent Beta install. If you havenโ€™t already, we recommend:
Checking for apps running in the background using Device Care > Battery > Background usage limits
Restarting the device and clearing the cache partition (via Recovery Mode)
Monitoring high-usage apps in Battery Usage
If the issue continues, please submit an error report via the Samsung Members app with detailed battery stats, so we can help investigate further.
Regards,
One UI Beta Team
SammieGirl1
Discussions
Will this wipe the device?
Teostar
Discussions
I'm having a similar issue with battery drain on my galaxy S23. I notice the location service icon showing up much more often than before ( I deliberately restrict location to only maps related apps). And when I check which app is using the location it doesn't show anything.
Robert12345
Discussions
I only hope when you do come out with the state will version of the software update Hope it will fix the battery drain on the s23 ultra series
