Battery drain issues
(Topic created: 06-19-2023 06:00 PM)
dortyboy
Red Giant
Discussions
Since the second update on beta watch 5. The battery drain issue has not been resolved
Discussions
Are you looking for suggestions how to reduce battery drain
dortyboy
Red Giant
Discussions
Either. Have you experienced that?
Discussions
I have and I could offer you a few Solutions if you'd like
Discussions
I first would check to see if the live captions feature is actively on. This feature often times is on without the user's awareness and does contribute to a significant battery drainage you could also look at your Google Play services another battery drainer contributing up to 10% of your daily battery consumption
dortyboy
Red Giant
Discussions
I was referring to the watch 5 not my phone
EOGO
Comet
Discussions
Try to do what I told you, I hope I can help you, what about me? It helped me a lot disabling those functions
Discussions
The reason I first suggest live captions is it is almost always a feature that you don't really need do you really care that Google assist has your battery draining so they can respond to a command you probably don't even use that's what that one's all about
Discussions
If you'd like information about the Google Play services get back to me I'm not going to be rude and burglarize someone else's conversation, like what is happening right now
EOGO
Comet
Discussions
It is in Spanish but, open the Samsung Health app, then go to the app settings and check what you have activated. 20230619_181021_1000072538_1687223423.jpg20230619_181043_1000072539_1687223445.jpg20230619_181057_1000072540_1687223459.jpg20230619_181105_1000072541_1687223466.jpg
