Showing results forΒ
Search instead forΒ
Did you mean:Β
Battery drain πŸ”‹
(Topic created: 11-10-2022 06:41 AM)
Leyrad
Discussions
Even with recent beta update, my battery still drains fast. It's way worst than before beta. I think I will wait for the post beta version. Trying to figure out how to take beta off, if possible.
Stldelsol
Galaxy
Discussions
Withdraw from beta and use smartswitch to restore I believe
Ricardo66
Halo
Discussions
Huge issue my battery life decreased by half
Lounp
Galaxy
Discussions
Apps are not optimized yet
Andres29
Discussions
That was my issue but after thr 3rd update things have stabilized a lot. Now is giving me about 45mins to 1 hour of extra screen time, for the record my Fold3 never had good battery life before the Beta.
BeeFrmNYC
Cosmic Ray
Discussions
I haven't had this issue. I keep my phone in "power saving mode" and allow background data in apps settings for the most important apps like emails or Samsung health for fitness tracking. Have you tried turning that on? Screenshot_20221125_101507_Device care_1000005299_1669389307.jpg
BeeFrmNYC
Cosmic Ray
Discussions
Also, try turning off adaptive brightness & manually set your brightness. It's a killjoy on your battery as well. Screenshot_20221125_102140_Settings.jpg
