Battery drain
(Topic created: 12-14-2025 05:22 AM)
julielabeur
Discussions
My battery is draining faster than before.
Youu
Honored Contributor
Discussions
Have you wiped the cache from the cache partition and run galaxy app booster from the good guardians app?
-CROW-
Supernova
Discussions
If you use fast charge, then yes. Also, remember the phone needs two weeks to learn your usage after any update.
USBetaModerator3
Beta Moderator
Discussions
Hello,
Thank you very much for sharing your feedback.
To help us investigate further, please submit an Error Report through the Samsung Members app immediately after reproducing the problem:
1. Open Samsung Members โ†’ One UI Beta Program โ†’ Beta Feedback.
2. Select Error reports and attach any relevant screenshots or screen recordings (if available).
3. Make sure โ€œSend system log dataโ€ is enabled before submitting.
Important: For accurate log collection, please submit the report within 3 minutes of reproducing the issue.
We apologize for any inconvenience and appreciate your support in helping us improve the Beta experience.
Best regards,
One UI Beta Team
46m3csl
Comet
Discussions
Same here , was hoping for better battery life
