Battery problems at night
(Topic created: 09-18-2023 08:59 AM)
shneor05
Discussions
Since I installed the beta my phone gets very hot at night and has about 30 percent of its charge, does anyone know what can be done about it?
Mike-B
Comet
Discussions
Have you booted into recovery mode and then cleared the cache and repair apps? If not, I would suggest you try that first.
shneor05
Discussions
Can you explain how to do it?
Mike-B
Comet
Discussions
1. Turn off your phone (power down, not restart)
2. Hold Volume Up + Power Button until the logo shows up
3. Release the Power Button shortly after the logo appears
4. Continue holding Volume UP (don't release) until the recovery shows up, and you'll see clear cache and repair apps in the list. Use the volume up/down to move and the power button to select the option.
USBetaModerator2
Beta Moderator
Discussions
Hello,
Thank you for your feedback.
Please try the suggestions by @Mike-B  to clear device cache.  Users have reported clearing device cache and rebooting the device helps.
You can also try the suggestions listed here to improve battery life: https://www.samsung.com/us/support/answer/ANS00078987/
 If the issue still persists, please use the Samsung Members app to submit an error report.
We appreciate your contribution to the Beta Program.
Regards,
One UI Beta Team
