Call volume stuck when using doorbell calls
(Topic created: a week ago)
JayyMoses
Discussions
Not sure if anyone else has had this issue but I've noticed when talking through the video doorbell the volume bar gets stuck on controlling call volume only even after you've left the app and won't allow you to control or hear media because the phone gets stuck thinking you're on a call. I've had to go in and use the force close option to fix this majority of the time after talking through the video doorbell app.
LongHiker
Galactic Samsung Care Ambassador
Discussions
Have you contacted the developers of the video doorbell app for a resolution?
JayyMoses
Discussions
I have not since I didn't start until one of the beta updates. It'll probably be fine once we are in the final beta.
MikeDelia
Galaxy
Discussions
To me that sounds like the doorbell app has taken control of the speaker and microphone and after the doorbell call, the app hasn't released control.
Try Force closing the app after use, not just swiping out away but by going into app info then Force close
JayyMoses
Discussions
That's what I've had to do when it happens. It's not every time I open it but that's exactly what it's doing.
MikeDelia
Galaxy
Discussions
Yes then it sounds like the app isn't ready for one ui 8.5 or the app just has it messed up and you should contact customer service after stable one ui 8.5 this week if it's not fixed yet
USBetaModerator3
Beta Moderator
Discussions
Hello,
Weโ€™re sorry for the inconvenience youโ€™re experiencing.
To help the team accurately identify the cause of this issue, we kindly ask that you submit an Error Report immediately after reproducing the problem so that the relevant system logs can be captured.
1. Open Samsung Members โ†’ One UI Beta Program โ†’ Beta Feedback.
2. Select Error reports and attach any relevant screenshots or screen recordings (if available).
3. Make sure โ€œSend system log dataโ€ is enabled before submitting.
Important: For accurate log collection, please submit the report within 3 minutes of reproducing the issue and do not kill the task of the Samsung Members app until you receive notification that the error has been sent (about 5 minutes)
Your report will greatly assist the team in analyzing and improving the Beta experience.
Thank you for your continued support.
Best regards,
One UI Beta Team
