Rapid battery drain
(Topic created: 02-23-2026 05:52 PM)
Shahpour
Galaxy
Discussions
Rapid battery drain after beta 5, i have been using this the same way for the whe year, I have taken all the precautions, but This is seriously first time I have seen going %5 in matter of mind, and %50 in couple hoyrs
Youu
Honored Contributor
Discussions
Clear the cache from the cache partition download galaxy app booster from good guardians in the galaxy app store, and your battery life should be really good1771902120776.jpg
Shahpour
Galaxy
Discussions
Yes done all that, I am very tech savvy, this is different something has changed, good thing S26U is coming in Couple weeks ๐Ÿ™‚
USBetaModerator3
Beta Moderator
Discussions
Hello,
Thank you for sharing your experience regarding battery usage.
To help our team analyze battery drain accurately, please submit an Error Report through the Samsung Members app immediately after noticing abnormal drain:
1. Open Samsung Members โ†’ One UI Beta Program โ†’ Beta Feedback
2. Select Error reports
3. Briefly describe:
- The apps used prior to the drain
- Screen-on time duration
- Whether the device felt warm or hot
- Ensure โ€œSend system log dataโ€ is enabled before submitting
Important:
For battery analysis, please submit the report as below after observing the issue (battery logs are time-sensitive and do not kill the task of the Samsung Members app until you receive notification that the error has been sent (about 5 minutes).
1. Charge battery to 100%
2. Remove Charger
3. Use Device (Including screen-off, at least 6 hours)
4. Submit error report before charging back
We appreciate your cooperation and continued support in helping improve One UI through the Beta program.
Best regards,
One UI Beta Team
GarryHart
Cosmic Ray
Discussions
I have the same issue
bluefire
Comet
Discussions
Agree. Having the same issue
