- Mute
β02-11-2023 09:23 AM in
Note20I have a Samsung Galaxy Note20.
I set up Driving mode on the "Modes and Routines" Samsung app, set it to "Do Not Disturb" and set it to block any calls or texts from people not in my address book when I'm connected to my car's Bluetooth. But, it doesn't actually block them, it sort of blocks them.
Instead, when a call comes in it mutes whatever I'm listening to (including the FM radio!), my car radio shows "Receiving", but there's no way to either answer or dismiss the call. My actual phone doesn't ring or vibrate and no call is shown on the phone display, but my radio things there's a call coming in so it mutes the audio. I can't do anything but wait until it goes to VM and then my media will start playing again.
So, rather than not being disturbed, I'm actually more disturbed since the audio is muted and there's no way to dismiss the call.
How do I fix that so it actually blocks the calls?
- Mute
β02-22-2023 09:56 PM in
Note20- Mark as New
- Mute
β02-26-2023 11:16 AM in
Note20No "Notifications" sub-menu in the Modes and Routines Do Not Disturb area, only "Calls & Messages" and "Apps"
- Mute
β03-03-2023 11:37 PM (Last edited β03-03-2023 11:39 PM ) in
Note20This is what my menu looks like.
- Mute
β03-04-2023 04:36 AM in
Note20It has gotten the Android 13/OneUI5.0 update.
My general Do Not Disturb menu in the main settings looks like that, but my question is about the Samsung Modes and Routines app/function. The Do Not Disturb menu in Modes and Routines does not have a notifications sub menu.
- Mute
β03-06-2023 08:27 PM (Last edited β03-06-2023 08:35 PM ) in
Note20If your Do Not Disturb settings are not configured correctly, you will continue to get interruptions while it's on. You'll need to configure the Do Not Disturb menu (you can long press the DND quick-toggle button in your notification pull-down bar) in order to keep from being interrupted. It's possible it's the notification pop-up coming through that mutes the music during a call. Perhaps blocking the notification may keep the music playing?
You can also try setting up that setting that lets you play audio from more than one app at the same time. I think it's called Separate App Sound. Enable it for all apps and then even if you get a call - you can route it through the phone speaker, Bluetooth should continue playing music.
- Mute
β04-27-2023 12:10 PM in
Note20
