- Mute
02-16-2021 07:12 AM in
Note20Solved! Go to Solution.
- Mute
02-18-2021 10:12 AM (Last edited 02-18-2021 10:13 AM ) in
Note20Disable Wi-Fi Calling. (Go to the Phone app, tap the vertical menu icon at the top right, and select settings. Toggle Wi-Fi Calling off).
Disable Advanced Calling (Settings > Connections > Advanced Calling > Toggle Advanced Calling off)
Reboot your device
Repeat the steps, first reactivating Advanced Calling, then Wi-Fi Calling). Wi-Fi Calling won't work correctly without Advanced Calling features enabled.
My best guess. Hope it helps!
- Mute
02-16-2021 08:44 AM in
Note20From settings > General management > Reset > Reset Network Settings (BEAWARE THIS WILL UN INSTALL YOUR WIFI AND BLUETOOTH DEVICES AND AFTERWARDS YOU WILL NEED TO RE INSTALL YOUR WIFI AND BLUETOOTH)
I had same issue, and this worked for me
- Mute
02-16-2021 09:06 AM in
Note20- Mark as New
- Mute
02-18-2021 09:40 AM in
Note20- Mark as New
- Mute
02-18-2021 09:45 AM in
Note20- Mark as New
- Mute
02-18-2021 09:52 AM (Last edited 02-18-2021 09:57 AM ) in
Note20- Mark as New
- Mute
02-18-2021 09:54 AM in
Note20- Mark as New
- Mute
Reboot your device
