Samsung Picture Frame Widget missing settings cog on Note 20 Ultra 5g
(Topic created: 11-09-2020 02:02 PM)
userD7yLQCO5Ds
Note20
Since I got my Note 20 Ultra 5g the Samsung Picture Frame Widget lacks the settings cog, effectively rendering the widget unusable since all of the widget's functionality is access through the settings cog.
Judging by the reviews on the galaxy store from people with the same phone switching their review scores to 1 and .5 star, the widget is broken for everyone with the Note 20 ultra.
I and many others would really appreciate if this widget is fixed ASAP, since no other picture frame widget is nearly as good as Samsung's.
Screenshot_20201112-145640_Nova_Launcher.jpgScreenshot_20201112-145651_Nova_Launcher.jpg
userD7yLQCO5Ds
Note20
Oof.
I'm using Nova Launcher Prime, I just switched to One UI and the settings do come up on long press on top of the widget.
Seems like Samsung made the widget settings and gestures only accessible through their One UI and locked out all 3rd party launchers for Android 10+. You used to be able to access all widget features on with 3rd party launchers on pre-Android 10 phones.
Mystery solved.
SamsungAdam
Note20
I would recommend reaching out to the developers of the Samsung Picture Frame widget at secgallery@samsung.com.
plano-mano
Red Giant
Note20
what do you mean 'missing settings cog'???
can you attach a screen shot?
userD7yLQCO5Ds
Note20
The settings cog that allows you to select fit options, transition time, select photos etc, does not exist on the Note 20 Ultra 5g version of the widget.
plano-mano
Red Giant
Note20
thats weird.. when i long press the widget, it gives option to resize(you know the blue frame with dots on each side) and when i click widget settings thers 'Slideshow interval', layout, add images, and image potision option.
are you using a launcher or theme? ur homescreen icon looks different than mine
userD7yLQCO5Ds
Note20
Oof.
Mystery solved.
