AOD issues after using Power Saving mode
(Topic created: 08-07-2026 12:38 PM)
chef_brian10
Questions
I'm aware that Power Saving disables AOD while in use but AOD continues to be disabled even after turning off Power Saving. I have to Manually go back into AOD settings and turn it back on. Not sure if this is an S26U issue or OneUI issue (was an issue with OneUI 8.5 as well).
ansarimsj
Cosmic Ray
Questions
Been experiencing the same issue in my s26 ultra with one ui 9.
Also, never experienced in my s25 ultra
USBetaModerator3
Beta Moderator
Questions
Hello,
We’re sorry for the inconvenience you’re experiencing.
To help the team accurately identify the cause of this issue, we kindly ask that you submit an Error Report immediately after reproducing the problem so that the relevant system logs can be captured.
1. Open Samsung Members → One UI Beta Program → Beta Feedback.
2. Select Error reports and attach any relevant screenshots or screen recordings (if available).
3. Make sure “Send system log data” is enabled before submitting.
Important: For accurate log collection, please submit the report within 3 minutes of reproducing the issue and do not kill the task of the Samsung Members app until you receive notification that the error has been sent (about 5 minutes)
Your report will greatly assist the team in analyzing and improving the Beta experience.
Thank you for your continued support.
Best regards,
One UI Beta Team
