Showing results forย
Search instead forย
Did you mean:ย
Android auto does not work
(Topic created: 12-21-2024 08:37 PM)
userNiko
Questions
I tried to use android.It doesn't work
userElqb8Nmunv
Questions
it does I've been using it all week. try restarting your phone, clearing cache + data in the android auto and google apps, resetting your car, or just turning it off and back on again (or using a different cable). definitely not a beta issue
Carljohnson52
Nebula
Questions
Working fine for me
lostone123
Galaxy
Questions
Turn your car on
Negropy
Galaxy
Questions
๐Ÿ˜‚
GuerreroMKL
Cosmic Ray
Questions
I am having an issue with Android Auto re-engaging after I take my phone out of my Car while it's running.
useraPnxlimral
Cosmic Ray
Questions
The only glitche I've noticed is that AA won't start unless I first unlock my S24U, even though I have AA set up to "Start AA while locked."
brucem6923
Questions
The only issue i have with Android Auto in i have to start Sirius/XM on my phone in order for it to play. I figure that it will be resolved with final release.
USBetaModerator3
Beta Moderator
Questions
Hello,
Thank you for sharing your feedback with us.
We are aware that certain Bluetooth models are experiencing disconnection, and fix is applied on the next update.
We truly value your input and appreciate your active participation in the One UI Beta community.
Best regards,
One UI Beta Team
