Battery Draining at Light Speed
(Topic created: 08-03-2024 10:45 AM)
BigSlam
Questions
My Galaxy Watch 6 Classic was working great in the beta until August 1st. Suddenly the battery just started draining fast and would be dead within 8 hours. I haven't added any software or changed aby settings. I even did a full reset and the issue is still happening.  Any thoughts?
Questions
I rebooted my Watch 6 into recovery mode and cleared the cache. I just installed the August beta update earlier today, but five hours later my watch went from 93% to 92%.
Questions
USBetaModerator3
Beta Moderator
Questions
Hello @BigSlam ,
Thank you for your feedback.
To help us better understand this issue, please submit an error report through the Samsung Members or Galaxy Wearable app on your device:
Galaxy Wearable Beta app> Search for "Contact us" as key words > Error reports (Screenshot would be more helpful)
Note: To ensure relevant log information is included in the error report, do not close the Samsung Members app until you receive a notification that error has been sent.
We apologize for the inconvenience and appreciate your contribution to the beta program.
Regards,
One UI Beta Team
