Battery drain
(Topic created: 09-12-2023 02:40 PM)
Bigboss3rm
Cosmic Ray
Questions
Showing significantly higher battery drain with or with out screen on. There isn't any one particular app drain , seems like they all are graining more than usual .
Ricardo66
Halo
Questions
Battery drain has doubled
USBetaModerator2
Beta Moderator
Questions
Hello,
Thank you for your feedback.
To improve battery life, please try the following:
Please erase the device cache using steps below. If issue persists, Please update Samsung members app to latest version from galaxy store and send us an error report from the Samsung member’s app -> Beta Feedback -> Error Reports to help us debug the issue.
1. Turn off the device.
2. Press and hold the Volume Up key and the Side key.
3. When the Android logo displays, release both keys.
4. An 'Installing system update' message may show briefly before the Android Recovery menu options appear.
5. Press the Volume down key several times to highlight Wipe cache partition.
6. Press Side key to select.
7. Press the Volume down key to highlight Yes, then press the Side key to select.
8. When the process is complete, Reboot system now is highlighted.
9. Press the Side key to restart the device.
Regards,
One UI Beta Team
