Showing results forย
Search instead forย
Did you mean:ย
Battery drain
(Topic created: 06-13-2025 05:50 PM)
1way2level
Cosmic Ray
Discussions
Has anybodys battery been draining faster on the beta?
Chaz187
Halo
Discussions
No, I have had amazing battery life on both Beta 1 and 2 so far!
Youu
Honored Contributor
Discussions
Clear the cache and run galaxy app booster from good guardians and your battery life should be really good
Youu
Honored Contributor
Discussions
Battery life seems a bit bad compared to beta 1, I hope you logged and reported it to samsung
1way2level
Cosmic Ray
Discussions
Its still pretty good but a bit worse then when I was on one ui 7
MrBobKing
Galaxy
Discussions
At first it was horrible. Then a couple days later I got like a whole day and then some. Since B2, I'm at 48% at 7:30 pm from a 6:00 am unplugging. I did the cache and the Booster app.
Bird1977
Cosmic Ray
Discussions
My charge seams to be lasting longer, however the charging process seams unstable. One time my battery will charge in 2 hours and another it will take 4 to 5 hours
USBetaModerator3
Beta Moderator
Discussions
Hello,
Thank you very much for your feedback.
To assist us in resolving this issue, we kindly ask you to submit an error report through the Samsung Members app on your device immediately after the issue is reproduced:
1. Open Samsung Members.
2. Navigate to One UI Beta Program > Beta Feedback.
3. Attach any relevant screenshots or screen recording/video (if possible).
4. Ensure "Send system log data" is checked, then submit the report.
Important: Please submit the report within 3 minutes of reproducing the issue for accurate log data collection.
We sincerely apologize for any inconvenience this may have caused and truly appreciate your contribution to improving the Beta experience.
Best regards,
One UI Beta Team
