Battery drain
(Topic created: 04-13-2026 11:55 AM)
Shunody
Cosmic Ray
Questions
Have you guys seen your S25 Ultra battery wont last that much, mine says battery isngood but have to charge more often , now I have to place it in saving mode so it can last.
userTZVKBzgIx0
Cosmic Ray
Questions
Search in settings, look for scanning. Turn off wifi , bluetooth and printing scanning. Saves you lil juice
USBetaModerator3
Beta Moderator
Questions
Hello,
We’re sorry for the inconvenience you’re experiencing.
To help the team accurately identify the cause of this issue, we kindly ask that you submit an Error Report immediately after reproducing the problem so that the relevant system logs can be captured.
1. Open Samsung Members → One UI Beta Program → Beta Feedback.
2. Select Error reports and attach any relevant screenshots or screen recordings (if available).
3. Make sure “Send system log data” is enabled before submitting.
Important: For accurate log collection, please submit the report within 3 minutes of reproducing the issue and do not kill the task of the Samsung Members app until you receive notification that the error has been sent (about 5 minutes)
Your report will greatly assist the team in analyzing and improving the Beta experience.
Thank you for your continued support.
Best regards,
One UI Beta Team
