Battery info
(Topic created: 08-12-2023 09:44 AM)
Robin621k
Honored Contributor
Questions
Am I crazy and can't find it, you can't see total SoT anymore since you unplugged from your charger. You can now only see the current day.
I don't like the new battery section .
Jeffrey_Jpeg
Cosmic Ray
Questions
Hitting view details should show how much SoT you've had.
Robin621k
Honored Contributor
Questions
The whole page is different, I didn't do a screenshot, when I checked before plugging in, it tells you SoT for the current day, not cumulative
Jeffrey_Jpeg
Cosmic Ray
Questions
Ah okay, I appreciate the heads up. Sorry about that.
DrFed
Comet
Questions
Yeah, it would be nice if we could see SOT since last full charge. I'm still dissecting it, but unfortunately I don't think SOT resets once battery is fully charged. I think Samsung is just giving us the SOT over a 24 hour period, which is not as useful IMHO.
USBetaModerator2
Beta Moderator
Questions
Hello,
Thank you for your Feedback. We appreciate your contribution to the Beta community.
Regards,
One UI Beta Team
