Showing results forย
Search instead forย
Did you mean:ย
Bugged battery level widget
(Topic created: 03-16-2025 11:31 AM)
Jeffry0001
Questions
Does anyone else also experience the problem that the battery widget shows the battery level and the icon together, and not separately as it should?
1 Reply
USBetaModerator3
Beta Moderator
Questions
Hello,
Thank you for sharing your valuable feedback with us. We truly appreciate the time and effort youโ€™ve taken to contribute to the One UI Beta community.
Your input is essential in helping us identify areas where we can improve and refine the One UI experience.
Weโ€™re grateful for your active participation and support in shaping the future of One UI. Please feel free to share any additional insights or suggestions you might have.
Regards,
One UI Beta Team
