Camera macro problem
(Topic created: 09-10-2025 09:15 AM)
Dasvenson1
Cosmic Ray
Questions
Has anyone else experienced a problem with the camera's macro focus not working since being on beta? It flickers and makes a snapping sound, while not focusing correctly.
This stops if macro is turned off, but cannot maximize photo quality of macro settings.
-CROW-
Supernova
Questions
No it's working fine
Prika33
Halo
Questions
Yep! Ive had this since Beta 4...its really bad when I try to take video now 😞
USBetaModerator3
Beta Moderator
Questions
Hello,
Thank you for your feedback.
To help us understand your issue, we kindly ask you to submit an error report with below information:
1) Video/screen recording of the current camera status (when zooming /focusing, camera flickers and makes snapping sound)
2) Check "Send system log data" and do not close the Members app until error report is submitted successfully.
We sincerely apologize for any inconvenience this may have caused and truly appreciate your contribution to improving the Beta experience.
Best regards,
One UI Beta Team
Dasvenson1
Cosmic Ray
Questions
This has been done
