Ilovechicken03
Star
- Mute
ā11-21-2021 05:26 PM in
Questions
I've seen that the s21 ultra has gotten that feature but the note 20 ultra which I have right now doesn't have that in the beta please respond and add it into the next update
Solved! Go to Solution.
Robert3301
Halo
- Mute
ā11-21-2021 06:28 PM in
Questions
Is that the enhanced processing tab
Robert3301
Halo
- Mute
Questions
Ilovechicken03
Star
- Mute
ā11-22-2021 04:35 AM in
Questions
Yea it is
USBetaModerator
Beta Moderator
- Mute
ā11-22-2021 12:19 PM in
QuestionsHello @Robert3301 ,
Thank you for suggesting the solution. We appreciate your contribution to the Beta community.
Regards,
One UI Beta Team
Robert3301
Halo
- Mute
ā11-22-2021 07:58 AM in
Questions
It should be up in your notification panel if it's not visible it the three little dots in the corner and you should be able to bring it down.
