Edge panel is hard to summon
(Topic created: 08-25-2022 09:30 PM)
ansel
Cosmic Ray
Questions
After upgrading to the beta swiping to get the edge panel to open often takes multiple tries and has become very hard to summon. Is anyone else having this problem?
Update: what's interesting is it only seems to be an issue when it's on the right side of the screen which is where I always used to keep it. When I move it to the left side it triggers immediately like it should.
Dhawk1202
Nebula
Questions
I'm not sorry. TMobile locked s22.
Ryan891
Supernova
Questions
Working fine here
USBetaModerator
Beta Moderator
Questions
Hello,
Please erase the device cache using steps below. If issue persists, Please update Samsung members app to latest version from galaxy store and send us an error report from the Samsung member’s app -> Beta Feedback -> Error Reports to help us debug the issue.
  1. Turn off the device.
  2. Press and hold the Volume Up key and the Side key.
  3. When the Android logo displays, release both keys.
  4. An 'Installing system update' message may show briefly before the Android Recovery menu options appear.
  5. Press the Volume down key several times to highlight Wipe cache partition.
  6. Press Side key to select.
  7. Press the Volume down key to highlight Yes, then press the Side key to select.
  8. When the process is complete, Reboot system now is highlighted.
  9. Press the Side key to restart the device.
Regards,
One UI Beta Team
