Extreme Battery Drainage
(Topic created: 12-29-2024 10:13 AM)
Questions
Anyone else facing battery drain issues on beta 2? I have an s24 plus and beta 2 has introduced the worst battery life I've ever seen on this phone, battery in device care says it'll get me about a day full charge, which is what it said before I joined the beta but im struggling to get half a day even though I've only used the phone for social media and music, nothing that is demanding. I've lost 80% battery in less then half a day. The phone also gets pretty warm doing these light tasks, hotter then it used to be. I was wondering if anyone else has these issues? Comment below, let's see if this is something that Samsung needs to fix.
USBetaModerator3
Beta Moderator
Questions
Hello,
We’re sorry to hear that you’re experiencing battery drain and heating issues with Beta 2 on your Galaxy S24 Plus. Beta software is designed to test new features, but sometimes it can cause unexpected behaviors like this.
To help us investigate and address this issue, we recommend submitting an error report through the Samsung Members app on your device:
  1. Open Samsung Members.
  2. Navigate to One UI Beta Program > Beta Feedback.
  3. Attach any relevant screenshots or battery usage stats (if possible).
  4. Ensure the "Send system log data" option is checked, then submit the report.
Your detailed feedback helps our team identify and resolve potential bugs to improve the overall experience for everyone.
In the meantime, you can try these tips to optimize battery life during the beta:
  • Clear the cache partition of your device.
  • Check for apps running in the background that might be draining the battery.
  • Ensure all apps are updated to their latest versions through the Play Store and Galaxy Store.
We truly appreciate your patience and contribution to making One UI even better. If others are experiencing similar issues, we encourage them to share their feedback as well—it helps us pinpoint common trends and address them more effectively.
Best regards,
One UI Beta Team
Y0u
Honored Contributor
Questions
To date, the most frequently cited issue is the battery performance. I would suggest that the 51% of the feedback is concerning, while the remaining 49% report having a satisfactory battery. I would suggest that you reported this issue to Samsung record the usage of the battery to better understand the issue.
Questions
Do I report it in beta feedback?
Questions
Same here
Questions
Seems to be a widespread issue
RedOregon
Sun
Questions
If you haven't already, please report via the Beta Feedback area.
Questions
Got it
zumaz
Cosmic Ray
Questions
Please check one of my posts where I discuss about some apps that specifically drain battery and OneUI doesn't seem to recognize them or show us in the stats section. I started noticing the drain after a discord app update and then after I installed instacart. I've been vigilant about the issue and carefully checked behavior. I'm on beta 2 and you can see the battery is fine.Screenshot_20241229_152542_Device care_1000029202_1735507542.png
sharp2200
Questions
Yes I have the ultra and my battery went from 50% at the end of the day to 30% at the end. That is some major problem because I have to make it through work. Don't know who to switch to because I heard oneplus 13 battery life isn't so great and they have a 6,000mah could be the chip.
USBetaModerator3
Beta Moderator
Questions
Hello,
Best regards,
One UI Beta Team
