Heat and Network Speed
(Topic created: 09-01-2026 07:07 PM)
RevengeOneUI
Nebula
Questions
I would love to send feedback in the app, but because I am currently in the UK, I can't.
There are two big issues that I'm hoping will get fixed before the stable build.
1) Heat. The phone gets way to hot while doing standard tasks, and cpu usage is high for basic things.
2) Network speeds. My phone, in the recent betas, has been using Network speeds slower than what the application needs, leaving me loading a Web page etc. for way longer than it should.
I understand this is a beta, but if this is because of "Network optimisation", I sure hope that gets fixed before the stable release.
Eli5173
Cosmic Ray
Questions
This is the watch beta, you maybe meant to post it elsewhere?
RevengeOneUI
Nebula
Questions
You are right. I'm using the web samsung community page and the options were listed without the categories properly, so I had 3 "questions" categories to choose from.
I meant to post it in the S26U beta forum.
Should I delete this and make a new post in the S26U forum, or should I assume it will be moved by a moderator?
Robin621k
Honored Contributor
Questions
Yes, copy then paste to the Ui9 Beta.
