Showing results forย
Search instead forย
Did you mean:ย
Maximum Privacy Display Toggle Issue
(Topic created: 07-15-2026 09:46 PM)
Asumsang1512
Galaxy
Questions
I always keep the maximum privacy display toggle on when using the feature and in prior beta updates it stayed on without me worrying about it. Now the maximum privacy protection toggle randomly turns off, I have no idea what is causing it and every time I toggle it back on later it turns off again. This issue has started as of beta 4. Has anyone else experience the same thing. Is there a user fix?
The Maximum privacy protection toggles off without my knowledge.
1 Reply
USBetaModerator3
Beta Moderator
Questions
Hello,
Weโ€™re sorry for the inconvenience youโ€™re experiencing.
To help the team accurately identify the cause of this issue, we kindly ask that you submit an Error Report immediately after reproducing the problem so that the relevant system logs can be captured.
1. Open Samsung Members โ†’ One UI Beta Program โ†’ Beta Feedback.
2. Select Error reports and attach any relevant screenshots or screen recordings (if available).
3. Make sure โ€œSend system log dataโ€ is enabled before submitting.
Important: For accurate log collection, please submit the report within 3 minutes of reproducing the issue and do not kill the task of the Samsung Members app until you receive notification that the error has been sent (about 5 minutes)
Your report will greatly assist the team in analyzing and improving the Beta experience.
Thank you for your continued support.
Best regards,
One UI Beta Team
