Power saver
(Topic created: 02-14-2026 06:44 PM)
userJ2NQpP8okJ
Questions
Has anyone found some of the settings gets set back to "on" after you have set it off? For example, before the beta, I played around with the Maximum Power saver mode. I left it on. I went into beta. So when the power saver turned on because of the adaptive power saver was on, it worked. But when I turned it off (both maximum and adaptive), it turned on all on its own, this happens at least one time a day..
Has anyone have this problem?
1 Reply
USBetaModerator3
Beta Moderator
Questions
Hello,
Thank you very much for sharing your feedback.
To help us investigate further, please submit an Error Report through the Samsung Members app immediately after reproducing the problem:
1. Open Samsung Members โ†’ One UI Beta Program โ†’ Beta Feedback.
2. Select Error reports and attach any relevant screenshots or screen recordings (if available).
3. Make sure โ€œSend system log dataโ€ is enabled before submitting.
Important: For accurate log collection, please submit the report within 3 minutes of reproducing the issue and do not kill the task of the Samsung Members app until you receive notification that the error has been sent (about 5 minutes)
We apologize for any inconvenience and appreciate your support in helping us improve the Beta experience.
Best regards,
One UI Beta Team
