S21 -- T-Mobile Data Problem
(Topic created: 10-14-2023 07:28 PM)
cpknupp
Galaxy
Questions
Hey. Seems like the one ui 6 beta is giving me problems with calling. When anyone calls me it seems to go right to voicemail most of time. And either says searching or emergency calls only. The odd thing is I definitely have service and I'm able to use data for games and Internet.
EmanCan
Questions
Mine is acting similar. I have the Emergency Calls only notice on top if I swipe down. Calls are going straight to voicemail. Texts are very glitchy as sometimes they are taking more than 10 minutes to receive.
cpknupp
Galaxy
Questions
The only solution I've come across is just shutting off 5g in cellular settings. It sucks but only work around unless u wanna possibly miss calls.
harry2763
Halo
Questions
As of right now. I'm not experiencing it.
user6j4mflKI75
Questions
Mine also
Floppa56
Questions
Same here it will just happen randomly and my only fix was to restart which is annoying.
SkullbasherJ
Questions
Had this twice in a week. And that's the only solution I've found so far.
