wifi problem
(Topic created: 12-16-2024 02:35 PM)
AliKaya
Cosmic Ray
Questions
When I installed the UI7 beta version, I was constantly experiencing wifi disconnections. When I installed the UI7 beta version, I was constantly experiencing wifi disconnections. I reported this and wrote about it here. The second update came and I installed it as well. Among the innovations in the second update, they stated that they solved the wifi problem, but nothing has changed. The constant wifi disconnections continue. This situation is seriously starting to get annoying. Before the UI7 update, the wifi connection never disconnected even when I went out of the house, but now the connection disconnects even when I am next to the modem.
Kett
Cosmic Ray
Questions
Yes, I have been experiencing this as well. I thought it was my Wi-Fi. So I guess this is a beta problem.
AliKaya
Cosmic Ray
Questions
I'm glad I'm not alone but I'm sad that we're going through this.
Questions
Did you try wiping cache in recovery mode?
AliKaya
Cosmic Ray
Questions
Yes, I tried. Nothing changed even though I tried all the methods.
Benkurut
Questions
Same here... Sent feedback. Do the same so they can fix it.
AliKaya
Cosmic Ray
Questions
I also created a report and the update came but this error is still not resolved. I will create a report again
USBetaModerator3
Beta Moderator
Questions
Hello,
Thank you for sharing your feedback with us (and your error report).
We truly value your input and appreciate your active participation in the One UI Beta community.
Best regards,
One UI Beta Team
userJl3tyBnNeV
Questions
I'm not seeing disconnects but have been experiencing speeds that are half of what they were.
