Showing results forĀ
Search instead forĀ
Did you mean:Ā
Add option to power phone through charger when using maps
(Topic created: 12-19-2024 08:20 PM)
dsrhodes06
Suggestions
It would be nice to have an option so that while using maps, we can power the phone through the charger when you are using maps in the car, for example. Similar to in games. It'd be helpful for when you charge your phone at night and only have a wireless car charger or your car uses Android Auto via cable so you are not putting so much strain on the battery
