Battery Icon should be more bigger wider
(Topic created: 12-26-2024 07:13 PM)
Rotondo
Halo
Suggestions
I wish there was a way we can get the same battery icon as the iPhone has because it is very detailed and definitely very visible if there is anyway maybe on one of the later one UI 7 beta stages they can implement it
Like in this screenshot I took.
youu
Black Hole
Suggestions
I agree
retrofred
Halo
Suggestions
I also agree that it should be wider
KBWolf
Nebula
Suggestions
I think it should always be the width of when it has one of the status icons in it (charging, battery protect, power saving, etc.) That way it's always one consistent width and is more readable.
Rotondo
Halo
Suggestions
Yes your right because while it's charging the battery icon seems more longer should stay that way
AlienX
Comet
Suggestions
Yeh, it's a bit small. The size looks a lot better if you turn on "Power Saving Mode" or connect to a charger.20241227_103927_1000020841_1735314111.jpg
USBetaModerator3
Beta Moderator
Suggestions
Hello,
Thank you for sharing your valuable suggestion.
We have forwarded your feedback to the development team for review. The project manager is currently evaluating its alignment with our design concept and goals. If your suggestion aligns with our direction, we will consider applying it to the official release.
Thank you for your continued participation in the Beta program.
Best regards,
One UI Beta Team
Rotondo
Halo
Suggestions
Yes if you can maybe please implement the iPhone battery icon on the beta because it is very much pronounced and visible to all our Samsung family 😎😎😎 maybe you can spread the word
