Showing results forย
Search instead forย
Did you mean:ย
Battery icon in quick settings panel
(Topic created: 06-10-2025 05:00 PM)
userZNnTdcqwZP
Supernova
Suggestions
"Don't fix what isn't broken" but I am just wondering if some Quick Settings icons could use an update. For example, battery icon. Why not, at least, make it horizontal to match the one in the status bar?
Youu
Honored Contributor
Suggestions
I agree
a63548
Cosmic Ray
Suggestions
I agree as well for consistency, but also wish there was an option in Good Lock to have the battery be vertical again like in the past.
USBetaModerator3
Beta Moderator
Suggestions
Hello!
Thank you for sharing your feedback with us. We appreciate you taking the time to provide your thoughts and suggestions.
We will share your feeback with the relevant team for review and consideration in future updates.
Thank you for supporting One UI Beta Program!
Regards,
One UI Beta Team
