Battery indicator for charging and low status
(Topic created: 12-07-2024 03:20 PM)
AlienX
Comet
Suggestions
The battery color should be kept green when the charger is connected and the color should also change to red when battery falls below 20% and not charging. This would definitely improve the user experience and not make us squint all the time to read percentage text.
ColinM
Galaxy
Suggestions
The color does change when the battery is low. It turns red at 15% the same time you get the "connect charger" notification
USBetaModerator3
Beta Moderator
Suggestions
Hello,
Thank you for sharing your valuable suggestion battery charging color.
We have forwarded your feedback to the development team for review. The project manager is currently evaluating its alignment with our design concept and goals. If your suggestion aligns with our direction, we will consider applying it to the official release.
Thank you for your continued participation in the Beta program.
Best regards,
One UI Beta Team
