Battery percentage in battery icon
(Topic created: 08-20-2023 08:38 PM)
HybridMoment
Cosmic Ray
Suggestions
Currently the battery icon and battery percentage are 2 separate items
 I think it would be much more modern to combine the two into a single icon
Faith7777
Comet
Suggestions
Yes! That's would be perfect t.
USBetaModerator2
Beta Moderator
Suggestions
Hello,
Thank you very much for your suggestion.
Your suggestion has been communicated to the developer and the development project manager is reviewing the content. After reviewing your suggestions, we will apply them to the official version if your proposal matches our concept.
We appreciate your contribution to the beta program.
Regards,
One UI Beta Team
DeLoreanCowboy
Cosmic Ray
Suggestions
An option not to do this would be great too. The way you're asking is how it is on iOS and I feel it's easier to see with them separate as they are now.
usernqA7PoWeVZ
Suggestions
It's been in android long before iphone. Just not in oneui
Suggestions
Agreed, having those 2 separate in my opinion looks awfull , too much going on up there and doesnt look modern , and it should also display a color based on the %. The whole battery icon should be re-designed so it actually looks modern and sleek.
Bertolo
Comet
Suggestions
I agree 👍.
Gerso
Cosmic Ray
Suggestions
Yes
Suggestions
Much easier to read separate.
