Battery Drain at Idle
(Topic created: 11-04-2023 11:42 AM)
Bertolo
Comet
Suggestions
I am currently using the Galaxy S23 and the overnight battery drain has not improved with the Android 14. Overnight from 11:30pm - 7:00am the battery drains 4%. I believe Samsung needs to focus more on the optimization of the battery at idle, to me losing 4% when the phone is unused is a waste of energy and the overnight battery drain should between 1% - 2% and it is possible because I am using another phone and the overnight battery drain is 1%.
ucancwhatic
Supernova
Suggestions
@usmoderator2
userlQcCM1wRc8
Black Hole
Suggestions
You would need to put your phone into airplane mode so it is not doing any updates or notifications in the background. Turn off GPS and Bluetooth.
All of these run in the background and 4% is not bad considering.
Bertolo
Comet
Suggestions
When I have another phone draining 1% it is bad for me.
Suggestions
Because there's much less happening on that phone I bet. Are they set up the same? Always on Display will suck it out of your Samsung for example. And you're doing fine anyway. I lose more like 15% overnight.
BHW658
Halo
Suggestions
Also, check if you have apps running in the background. ✌🏼
Suggestions
Beta software usually drains the battery much faster than a final release due to all of the compiling in the background.
