Outtakes8302
- Mute
10-30-2023 07:25 PM in
Suggestions
In the notification shaie the device control shortcut is on the left and in the quick settings panel it's on the right. I don't care which side it's on, but it should be on the same side in both the notifications shade and quick settings panel.
1 Reply
USBetaModerator 2
Beta Moderator
- Mute
11-01-2023 08:14 AM in
SuggestionsHello,
Thank you very much for your suggestion.
Your suggestion has been communicated to the developer and the development project manager is reviewing the content. After reviewing your suggestions, we will apply them to the official version if your proposal matches our concept.
We appreciate your contribution to the beta program.
Regards,
One UI Beta Team
![](/skins/images/58878385BD23D56DF7D243861A43A427/responsive_peak/images/icon_anonymous_message.png)
