Edge Panel Apps Not Showing Icons If Using Third Party Launcher
(Topic created: 09-11-2023 02:23 PM)
Jaixe5587
Suggestions
The overlay for edge panels still functions and operates appropriately, but if using a third party launcher - the individual icons will appear *if they're on the main panel*. If inside a folder, however, they all show blank images.
missmotta
Sun
Suggestions
I noticed that they come back if you switch back to the default launcher, open a folder, then go back to your third party launcher again and try.
At least, this worked for me
USBetaModerator2
Beta Moderator
Suggestions
Hello,
Thank you very much for your suggestion.
Your suggestion has been communicated to the developer and the development project manager is reviewing the content. After reviewing your suggestions, we will apply them to the official version if your proposal matches our concept.
We appreciate your contribution to the beta program.
Regards,
One UI Beta Team
