Fix battery on s22
(Topic created: 10-12-2022 04:53 AM)
caden3ds
Halo
Suggestions
I used good guardian and cleared my cache but my battery still drains
ChevyMan1
Galaxy
Suggestions
I have noticed a faster battery drain with beta 4
user_ams007
Planetary Samsung Care Ambassador
Suggestions
Try opening up your settings and then go to the device care feature and then select The background usage limits and put unnecessary applications into a deep sleep or sleep which will help also, use the Samsung Good Guardians battery tracker to see if you have any applications that are running unrestricted background usage and battery settings that may be draining your battery
USBetaModerator2
Beta Moderator
Suggestions
Hello,
Thank you for your Feedback.
Please try the battery saving suggestions by @user_ams007 .  If you continue to run into issues with your battery, please use the latest Samsung  Members app to submit an error report.
We appreciate your contribution to the Beta community.
Regards,
One UI Beta Team
