Flex Mode Power Saving
(Topic created: 10-17-2023 07:16 PM)
neilth
Black Hole
Suggestions
Flex mode is a great feature to have on a foldable device. I would like to have the TouchPad half of the screen turn off, saving battery, if not used for a pre-configured interval. Touching the dark area would reawaken the TouchPad. This enhancement would be beneficial for activities like watching videos, or other activities not requiring user input while using Flex mode.
USBetaModerator2
Beta Moderator
Suggestions
Hello,
Thank you very much for your suggestion.
Your suggestion has been communicated to the developer and the development project manager is reviewing the content. After reviewing your suggestions, we will apply them to the official version if your proposal matches our concept.
We appreciate your contribution to the beta program.
Regards,
One UI Beta Team
1 Reply
USBetaModerator2
Beta Moderator
Suggestions
Hello,
Regards,
One UI Beta Team
