Hot fix for refresh rate issue is dropped.
(Topic created: 02-26-2025 01:32 AM)
Paul017
Cosmic Ray
Suggestions
bigbad614
Nebula
Suggestions
Downloaded mine. So far so good.
USBetaModerator3
Beta Moderator
Suggestions
Hello,
Thank you for your participation in Beta program.
We hope the hot fix for Screen Rate drop issue is fully resolved after the update.
Please don't hesitate to submit an error report if you encounter the same problem.
Regards,
One UI Beta Team
Youu
Honored Contributor
Suggestions
Thanks for the tip, downloading now
