Huge battery drain issue
(Topic created: 03-14-2025 02:11 PM)
incconutwo
Galaxy
Suggestions
Huge random battery drain on the Beta 4 update.
 Sometimes it's 10% per hour, other times it spikes to 30% per hour. When using 4G and hotspot, it fluctuates between 10% and 30% per hour. The drain seems completely random, making battery life unpredictable. Hoping for a fix in the next update
Youu
Honored Contributor
Suggestions
Have you tried clearing the cache partition and run galaxy booster from good guardians and report this issue to samsung
incconutwo
Galaxy
Suggestions
I did two reports and reset the phone twice, but will test the cache and the good guardians module.
Not applicable
Suggestions
It won't work if you already tried that.
incconutwo
Galaxy
Suggestions
Yeah probably a bug with beta 4
userx5VGYPEDOk
Suggestions
My battery is draining faster since beta 4 update.
userlQcCM1wRc8
Black Hole
Suggestions
Yes, I have had the random drain spikes as well.
Clear partician cache does help, but does not really identify the issue.
I turned off Adaptive battery and that did seem to limit the random spikes so far. Could be a bug with adaptive battery?
incconutwo
Galaxy
Suggestions
Really ? Will try and see if it work
Phoneybologna
Galaxy
Suggestions
My battery is much improved since beta 4
incconutwo
Galaxy
Suggestions
Can you show what your battery stats look like ?
