Showing results forย
Search instead forย
Did you mean:ย
Problems with calls.
(Topic created: 05-28-2025 04:23 PM)
DanielGuzmanBanos
Cosmic Ray
Suggestions
When I make calls When I make calls or get calls, I get a mistake.
wlm9700
Cosmic Ray
Suggestions
I am unable to make any calls on S25 Ultra
-CROW-
Sun
Suggestions
Try turning off your phone, removing the SIM card, and putting it back in. Then turn your phone on. If it still doesn't work, report the problem.
G87M2
Galaxy
Suggestions
No issues here with phone calls
steeda
Cosmic Ray
Suggestions
Make sure in settings>connections>mobile data>APN tap and make sure it's highlighted
DanielGuzmanBanos
Cosmic Ray
Suggestions
Thanks
ucancwhatic
Red Giant
Suggestions
Do you have bars on your signal indicator?? Do you have LTE service?
DanielGuzmanBanos
Cosmic Ray
Suggestions
Yes, if I have, it is more a question of when I am on the call, I get the mistake.
USBetaModerator3
Beta Moderator
Suggestions
Hello,
Thank you very much for your feedback.
To assist us in resolving this issue, we kindly ask you to submit an error report through the Samsung Members app on your device:
1. Open Samsung Members.
2. Navigate to One UI Beta Program > Beta Feedback.
3. Attach any relevant screenshots or screen recording/video (if possible).
4. Ensure "Send system log data" is checked, then submit the report.
Important: Please submit the report within 3 minutes of reproducing the issue for accurate log data collection.
We sincerely apologize for any inconvenience this may have caused and truly appreciate your contribution to improving the Beta experience.
Best regards,
One UI Beta Team
