Battery icon removal
(Topic created: 12-15-2025 11:38 AM)
chas099
Cosmic Ray
Tips
Just want to say I appreciate the ability to remove the battery icon and still have the battery percentage show, I can finally see percentage without eye strain.
Y0u
Honored Contributor
Tips
Nice, thanks for the tip, this has helped
user0BwG8qoRww
Tips
How did you remove the icon?
Philosophics
Comet
Tips
Settings - Notifications - Status Bar
Tips
Very much appreciated!
TonyMontanaLTU
Cosmic Ray
Tips
My question is if an option to keep the pill but remove the percentage still exists somewhere because I cannot find it anywhere, even when using Settings search bar. If it doesn't I suggest y'all to report it to Samsung via Beta Feedback so they notice and add that option back (I already reported that)
USBetaModerator3
Beta Moderator
Tips
Hello,
Thank you for taking the time to share your feedback.
Your input plays an important role in helping us improve the One UI experience.
If you encounter any issues or have additional suggestions during your One UI Beta participation, please continue to share them through the Beta Community or the Samsung Members app.
We appreciate your continued support for the One UI Beta Program.
Best regards,
One UI Beta Team
