Device control quick settings panel
(Topic created: 12-05-2024 08:40 PM)
Tips
If you're like me and didn't notice the device control button is gone from the quick settings panel and are wondering how you are supposed to toggle your smart lights tonight, well have I got a tip for you!
You have to click on the smart things button, you may get pop-ups asking about location access but you do not have to accept them. After you are in smart things, press on the word smart things and you will get a pop-up and we'll be able to select home. Now go back to your home screen and when you swipe down your quick settings panel it will say home instead of smart things.
USBetaModerator3
Beta Moderator
Tips
Hello @superboxman ,
Thank you for joining the One UI 7 Beta Program!
We hope you enjoy exploring the newest features. As you experience the Beta, feel free to share your comments or feedback at any time.
Your contributions are invaluable to improving the program.
Best regards,
One UI Beta Team
Y0u
Honored Contributor
Tips
Thanks for the tip, this was helpful to me
