Battery Drain
(Topic created: 04-27-2026 04:40 PM)
userWJPXNhHojh
Discussions
S24 Ultra seems to be training faster in this beta, Beta 3 so far has also had windows bugs when trying to multi- task as before it would not either. Gotta fix there's bugs.
R335
Cosmic Ray
Discussions
Did you send the beta feedback ?
USBetaModerator3
Beta Moderator
Discussions
Hello,
We’re sorry for the inconvenience you’re experiencing.
To help the team accurately identify the cause of this issue, we kindly ask that you submit an Error Report immediately after reproducing the problem so that the relevant system logs can be captured.
1. Open Samsung Members → One UI Beta Program → Beta Feedback.
2. Select Error reports and attach any relevant screenshots or screen recordings (if available).
3. Make sure “Send system log data” is enabled before submitting.
Important: For accurate log collection, please submit the report within 3 minutes of reproducing the issue and do not kill the task of the Samsung Members app until you receive notification that the error has been sent (about 5 minutes)
Your report will greatly assist the team in analyzing and improving the Beta experience.
Thank you for your continued support.
Best regards,
One UI Beta Team
