Battery Drain S24+
(Topic created: 12-06-2024 06:15 PM)
dgruttola93
Cosmic Ray
Discussions
I am experiencing horrible battery drain on my S24+. After my 13 hour shifts I used to always have atleast 40% battery left and that's with heavy use. Today after the same amount of usage my phone actually died before I even made it back to my house. I have not changed any of my settings around either. Is anyone experiencing the same issue as me? Whether it be on the S24+ or the ultra? My husband has the ultra and he noticed that his battery life is a lot better. I wonder if this is an issue with the S24+?
zdossed
Comet
Discussions
Can you provide a screenshot of your battery graph?
Kobe_kobito17
Cosmic Ray
Discussions
My battery has actually been SIGNIFICANTLY improved
teqKno82
Discussions
Same here. Very satisfied with this beta
Idaband
Cosmic Ray
Discussions
Same
ButtaBean_42
Neutron Star
Discussions
Battery drain is quite normal During Betas and also after a Software Update
bluefire
Comet
Discussions
And for a few bugs around there...
USBetaModerator3
Beta Moderator
Discussions
Hello @dgruttola93,
Thank you for your feedback on Battery Drain.
As others mentioned, battery drain is common during 1st Beta, as your phone is going through numerous changes in the software implementation (causing the phone to resist yet concur in the end = Battery draining).
Once the software is fully embedded in the system, your device should experience less of battery drainage but more of battery optimization.
Although, if the issue persists, please send us back the Error report (Via Samsung Members) to help us understand the issue.
Regards,
One UI Beta Team
Y0u
Honored Contributor
Discussions
Have you tried clearing the cache partition and run galaxy booster from good guardians and report this issue to samsung, so they can see what's eating the battery
