Showing results forΒ
Search instead forΒ
Did you mean:Β
Battery Drain
(Topic created: 11-18-2021 07:22 PM)
Gyan
Discussions
I just updated to one ui 4 beta, I feel like battery drains pretty faster than one ui 3.1. Anyone else facing same ?
Discussions
My battery is not draining in fact I am getting better battery life
Gyan
Discussions
Great. I think its draining more on standby than before for me.
bigT37
Discussions
It all depends on how much is still running in background how much stuff you have on and brightness all the stuff they tell you to turn of do so battery will last better and try to put enhanced processing on it helps lot the up date did nothing to battery life it's amount of stuff kept on also 2-4 times or every time I close all apps I push device care widget
userB035heVEA1
Discussions
I would have to agree with the additional drain. Battery life seems shorter so far on the Beta.
USBetaModerator
Beta Moderator
Discussions
Hello,
Please erase the device cache using steps below. If issue persists, Please update Samsung members app to latest version from galaxy store and send us an error report from the Samsung member’s app -> Beta Feedback -> Error Reports to help us debug the issue.
  1. Turn off the device.
  2. Press and hold the Volume Up key and the Side key.
  3. When the Android logo displays, release both keys.
  4. An 'Installing system update' message may show briefly before the Android Recovery menu options appear.
  5. Press the Volume down key several times to highlight Wipe cache partition.
  6. Press Side key to select.
  7. Press the Volume down key to highlight Yes, then press the Side key to select.
  8. When the process is complete, Reboot system now is highlighted.
  9. Press the Side key to restart the device.
Regards,
One UI Beta Team
