Battery Drain
(Topic created: 10-25-2022 10:28 AM)
DynamiteD
Discussions
My battery life on my Z Fold4 seems significantly lower on the beta of One UI 5. Drains much faster than it used too; was also having an issue where PayPal was draining significantly more battery than before the update. Had to put in deep sleep and still seemed to drain too much battery so deleted the app.
Jettie1767
Cosmic Ray
Discussions
I think about the same for mine. Some apps like United crashes on some features.
RicanSharl
Cosmic Ray
Discussions
Mine drains quite fast too. I've seen hight utilization from random apps. Attached an example when SHealth misbehaving. Screenshot_20221018_201600_Device care_1000003620_1666149371.jpg
ZeusDMAG
Comet
Discussions
Mine hasn't been too bad. It started off rough after the October update. But now it seems to have mellowed out a bit after the beta. Could always be better though..Screenshot_20221025_221803_Device care_1000000766_1666750683.jpg
DynamiteD
Discussions
I deleted PayPal, did a normal reboot, and then wiped the cache partition, and that seemed to calm things down a bit
dee32soon33
Cosmic Ray
Discussions
Mine too
MikeDeezy
Cosmic Ray
Discussions
All is well here. I don't have much garbage software though
alex061
Discussions
Hey all, I just install the beta 2 and I still have the battery drain... Idk why and the battery manager is not so helpful
