Battery Drain?
(Topic created: 11-01-2023 08:26 AM)
Jwes23
Cosmic Ray
Discussions
Since beta 3 has anyone noticed battery draining a little more? Seems like my battery my drain a little bit more than normal.
ButtaBean_42
Honored Contributor
Discussions
This is pretty much expected after an update
Chef31684
Red Giant
Discussions
It's standard right after an update. Plus what many people don't realize is their device usage goes up right after as well as they "test" things and apps.
Try wiping the cache partition of your device using recovery mode and then rebooting. Also going into Settings>Apps>Google Play Services>storage>clear cache
Both of these tips should help a little
Also try running Galaxy App Booster (official Samsung app)
Jwes23
Cosmic Ray
Discussions
Thanks! How do you do recovery mode again. It's been years since I've done that .
Chef31684
Red Giant
Discussions
Jwes23
Cosmic Ray
Discussions
Thanks it already seems to be better
Negropy
Galaxy
Discussions
I haven't seen significant drops. I have to say I wipe cache immediately after an update.
My2002m
Cosmic Ray
Discussions
I'm having significant drain after the 3rd beta release. I isolated the issue to how the new release is impacting my main email app. That app is now draining my battery even though it has not had any changes or releases in 30 days. So the operating system update caused the problem as I haven't had this issue before.
Negropy
Galaxy
Discussions
Perhaps the email app has not been optimized for Android 14?
